All events have optional event terminals on the left. Signaling events also have e.g. a "discard?" terminal on the right.
Hovering over them with the mouse does not generate any relevant context help, and maybe it should. (well, there is a tip string that simply duplicates what is already written on the terminal giving boring redundant information).
I suggest that hovering over an event terminal with the context help open should first of all tell us how these terminals are called in general ("Event Data Node", according to the help, but who knows that???), but also give specific information about each terminal under the cursor.
For example:
IDEA: I suggest to add relevant context help to all event data nodes. Thanks!
(Note that e.g. the "timed loop" terminal already have context help. This should be similar)
National Instruments will not be implementing this idea.
