User | Kudos |
5 | |
4 | |
2 | |
2 | |
2 |
I'd like to see something like a conditional disable structure that would be sensitive to fields in an .ini file at runtime, not compile time.
My problem is that I have an application that can access many different third party cameras. For this application to work every VI that accesses a camera specific .dll function must have assess to that .dll or I get a broken VI. When I compile the VI I have access to these .dlls but when I build an application.exe and distribute it I only want to distribute the .dlls for one of the cameras. If I could distribute a .ini file with the application.exe that indicated which camera the drivers were installed for then the application would disable the code for all the other cameras and the VI would not break.
Thank you,
Chuck Lippmeier
