silmaril
Conditional Disable Symbols in Build Specs
Status: Duplicate
Currently we can set Conditional Disable Symbols (CDS) for a whole project or for a target.
I wish we were able to set them inside a build spec, too.
This would mean, I could have a large application in one project and build different flavours of it's executable simply by using the appropriate build specs.
Use cases might include simple things like debug / release builds (similar to this idea), but also more complex differences like a software that uses real hardware and a special version that works without hardware, which can be used in the office.
Currently I need to either set the CDSs manually each time I build an executable or maintain several copies of the same project file. Both methods are tedious and error-prone.
3 Comments
TCPlomp
Trusted Enthusiast
This is a duplicate of Conditional Disable Symbols settable in Application Builder
Ton
My LabVIEW Ideas
silmaril
Oops, you're right. Sorry!
Please Kudo hfettig's idea if you agree with what I've written.
Laura F.
Status changed to: Duplicate
