DanyAllard
Compile Xcontrol
Status: New
Provide a way to compile an xcontrol, to have only 1 file to distribute.
LabVIEW ChampionArchitect
5 Comments
AristosQueue (NI)
NI Employee (retired)
I take it that putting the XControl and all its member VIs in an LLB is not a sufficient solution?
DanyAllard
What thinking of is some sort of EXE style file that hide the implementation and all used VI.
Edit: And you can drag en drop direcly on the front panel and you got the xcontrol.
Message Edited by Dany. on 06-04-2009 06:27 PM
altenbach
Knight of NI
Yes, maybe something along "built specifications...built control". This would make a plain "*.ctl" file that can e.g. be put in the user palette or distributed, but retains all functionality of the Xcontrol.
(examples could be an xy-chart (with settable history size) or a fake radio button control that allows up to two items selected, or even some fancy airplane control, such as an artificial horizon).
Still, I see some problems, e.g. it is probably not easily possible to support "advanced...customize" or even resizing.
TCPlomp
Trusted Enthusiast
The steps to accomplish this are:
Create a source code distribution as an LLB
Make the XControl the only top-level  element of the LLB.
Create a mnu file for the xcontrol and put it in the LLB (I am not sure if this works, if not place the mnu file next to the LLB.
Create an installer using VIPM or OpenG Package builder that places the LLB (+.mnu) inside user.lib
Ton
PS the need for the MNU file is because LabVIEW ignores XControls in the auto-palette builder.
My LabVIEW Ideas
TCPlomp
Trusted Enthusiast
A related idea is here (index xctl files inside user.lib)
My LabVIEW Ideas
