Matthias_H
Case structure with case sensitive/insensitive indicator
Status: Completed
Available in LabVIEW 2015 and later
this is NOT a duplicate of this one.
But I couldn't find a duplicate within a few minutes.
I'd like to have an indicator which shows if the case structure compares strings case sensitive or case insensitive:
Case Structure String Indicator
Regards
Matthias
18 Comments
fabric
This was the one that we decided was the best alternative given usability concerns, implementation details, and developer resources.
...and yet the proposed implementation is not so usable if the case structure is  very large. Did you consider at least putting the identifier on the same side as the case selector terminal? On very wide diagrams (which are common) it would at least be good to see the identifier before you add additional logic to the case selector input...
Darren
Proven Zealot
As I mentioned, we looked into several designs and placement alternatives. This included placing the glyph in the lower left. I'd have to talk to the team to remember why we didn't go with that location.
For larger structures where you can't see the entire structure, you're still able to right-click the border and see the current Case Insensitive Match setting.
fabric
My guess: Dragging the case selector to the very bottom would then clash with the case identifier... Of course, the select list would be the obvious place to put it but that particular choice probably required too many developer resources! Smiley Surprised
Shame, because the identifier needs to be as visible as possible to serve its purpose. Bottom-right feels like a slightly disappointing outcome for a generally good feature.
Thanks for the reply anyway! Smiley Happy
AristosQueue (NI)
NI Employee (retired)
No, it wasn't developer resources. The ring is a problematic choice because we would be adding this glyph to already shipping VIs. Putting the glyph on the ring would eclipse text that is already in the ring. Rings are frequently alredy clipping text; reducing the space for visible text further didn't seem likely to be appreciated.
The four corners are the locations where the text is least likely to have existing elements. A tunnel can be in the very corner, but it is so unusable from every direction that it is basically unheard of. The top corners are eclipsed by the selection ring. Frequently the case structure is shrunk until the selection ring is the full width of the top. So it comes down to the bottom corners.
After having it for a couple months, I'm tempted to say it should move to the left bottom corner so it is in line with the selection terminal -- it becomes something your eye catches on as you're watching execution highlighting and thinking about which frame is about to be selected.  Would that be an improvement?
fabric
Yes, IMO bottom-left would be much preferred. Your observation was the same as mine: That the identifier relates most to the case selector, and that having the two items near each other seems to make more sense. Coupled with the fact that the bottom-right corner may be (very) far away seals the deal for me.
donkdonk
bottom left seems more intuitive to me as well
AristosQueue (NI)
Here's a screenshot of LV 2015, final version that will ship in August:
As you can see, we moved to bottom left. Thanks for the feedback, everyone.
Darren
Proven Zealot
Status changed to: Completed
