When you do a source distribution build you have the option to specify files that should be excluded. However, you have to do this explicitly (either by adding all the files one by one, or create a folder containing them all - and then add that folder). Creating that list of exclusions can easily become a big task, and a maintenance nightmare. Instead it would be nice to have something like this:
So - I propose that we get an option to exclude the hierarchy of the files we add to the exclusion list. Just like we can choose to include all subVIs in a search within a VI for example, we can add the top-level VI and check a box next to it to exclude all its subVIs.
(Ideally I would like to be able to exclude even dynamically called VIs as well this way by simply specifying a *project* as excluded. All VIs referred to by the given project should then be excluded.)
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
