I have searched the forum but cannot find this particular issue - only the adaptive nature of the dropped constant.
When an Integer Numeric Constant is dropped onto the block diagram the value '0' is highlighted ready to accept a typed value. When you do the same thing with a DBL Numeric constant you have to double click it to highlight it before you can enter a value. This behaviour is inconsistent the Integer being preferred.
The 'suggestion' is to make the behaviour of the dropped DBL Constant the same as that of the dropped Integer Constant. i.e. highlight the dropped DBL ready to type the required value. Has anybody ever wanted the dropped DBL to be zero!?!
I may be mistaken, but I believe the inconsistency stems from the fact that the DBL constant is actually a VI set to Place VI Contents, rather than a true constant like the Integer constant. (See also)
JB - I think you have your definitions flipped. The space constant is an actual VI. Place VI Contents means that the VI itself is not place, but the code inside of it.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
The mechanism for selecting the constant value when you drop it from the palette is pretty separate from the mechanism for dropping the contents of a VI, so this one might be more challenging than it seems.
crossrulz a écrit : JB - I think you have your definitions flipped. The space constant is an actual VI. Place VI Contents means that the VI itself is not place, but the code inside of it.
Yes, you're right ! I know the difference but didn't take care enough while answering.
One workaround (extracted from the other thread on adaptive behaviors) is to use the Numeric Constant and type a trailing "." to get it to adapt to DBL automatically. That's actually more useful in this situation since you already need to type something into the constant.
