jorgeinSD
Array element location tip strip
Status: New
In large &/or dense &/or multi-dimensional arrays, it'd be helpful to be able to tell the location of elements without having to either manually count or use the index values to relate to an element's location. A default tip strip could work - see image below:
2 Comments
Kjell-E
Add to that a "row" and "column" tip-strip to the array index controls off to the side and we would be all set..
Project Engineer
LabVIEW 2009
Run LabVIEW on WinXP and Vista system.
Used LabVIEW since May 2005
Certifications: CLD and CPI certified
Currently employed.
Robert_J_Loomis_III
good idea, would be useful
