User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
This will help greatly with VIs that have a optional inputs. For any VIs that are attacehd to the connector pane, a boolean property should indicate whether or not a value was passed externally. This will facilitate a much more structured and visible set of default values and initialization. As another option, there could be a "Value(nargin)" option that will set the value wired to it IFF there is no supplied input.
