User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
Here's a very fundamental User Interface concept that LabVIEW lacks:
When you press and hold an increment or decrement button on a numeric/ring/slider...etc..., the rate at which the value changes is constant: painfully slow. Typically, in other applications, button presses will increase the rate of change of the number proportional to the amount of time held, and if you hold it for 5 seconds or so that sucker is flying.
We want the same native behavior for increment/decrement buttons in LabVIEW, but we want it to be configurable. Consider a Property Node that defines a Lookup Table for the velocity profile of the increment:
The way the above code is read: For 0<t<1000, the control only moves at 1unit/sec. For 1000<t<3000, the control moves at 10units/sec. For 3000<t<5000, the control moves at 100units/sec. Another (more difficult?) way to define the velocity profile is to provide the velocity profile vs. time as a formula.
Of course, while the "typical" profile would start off slow and accelerate, I'm sure the ability to create unique accel/decel profiles would give incredible control for some awesome, one-of-a-kind User Interfaces.
(As a side note, if LabVIEW simply implements a fixed acceleration rate that was non-configurable, I will still be frustrated and still take the XControl route.)
I'm sure someone can think of a better, more intuitive implementation, but the concept remains:
For a press-and-hold on Increment/Decrement buttons, the control should increase its rate of change proportional to the amount of time it has been held, as defined by the programmer.
