When using quick drop and calling a resizable function such as Build Array, Concatenate Strings, any of the many Array functions, etc... allow a modifier to be read that would automatically resize the function to the appropriate number of inputs.
As an example if I want to drop an index array function for a 2D array, I could use the quick drop string "Index Array-2"
Not specifying a modifier would result in only the base function being dropped.
The modifiers should also work with any custom shortcuts that the user defines such as "in-2" for "Index Array-2"
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
