kamoshida
Add an Option to Display Arrays in a Single Line in the Debug Window
Status: New
The new debug window in LabVIEW 2025 Q3 automatically expands arrays to show all elements across multiple lines. While this full view can be helpful, it often becomes disruptive during debugging.
I have attached a video that shows a side-by-side comparison. The left side is LabVIEW 2025 Q3, and the right side is LabVIEW 2024 Q3.
As you can see, when an array contains many elements, the new multi-line display consumes a large amount of vertical space on the block diagram. This pushes other probes and data displays down, causing their positions to shift and making it difficult to monitor them. There are many cases where I only need to see that the array contains data, not every single element, and I would prefer the more compact, single-line view.
I propose adding a feature to allow users to select the display mode for arrays in the debug window. It would be ideal to have a toggle or option to switch between the new multi-line view and the classic single-line view, similar to how it worked in LabVIEW 2024 Q3 and older versions.
This would provide the flexibility to choose the most appropriate view for the situation, greatly improving the debugging workflow and the visibility of other data on the diagram.
