sbus
Add Option to Display Conditional Disable Symbol Values from a Builds Executable
Status: Declined
I'd like a way to find out what the values of the defined Conditional Disable Symbols were set to when a project build was performed after it is distributed as an executable - from the executable. In a complex application setting symbols incorrectly for the build can cause issues that might be easily detected if the symbol's values were available for examination from the executable.
I can easily create that option manually in my application; but it seems that LabVIEW should provide a method to do this without me having to write code. It can't be a toolbar option; many LabVIEW distributed applications don't have one. I'd think maybe a control-key sequence that popped up a window listing the conditional disable symbols and the values of them used in the build would be a really great addition to LabVIEW.
2 Comments
shb
Somebody could write a prebuild or postbuild hook which uses the VIs described here:
http://forums.ni.com/t5/LabVIEW/Programmatic-read-access-to-project-symbols/m-p/2631165/highlight/tr...
Showing the results in the warning display would be nice, but I do not know how to do this. (I know it for the error window, but this fails the build.)
Darren
Proven Zealot
Status changed to: Declined
