LabVIEW FPGA Idea Exchange
vitoi
Smaller (and cheaper) sbRIO based on Xilinx Zynq
Status: New
A smaller (and cheaper) sbRIO based on the Xilinx Zynq chip. Target size is SO-DIMM form factor (68 x 30 mm (half the area of a credit card), 200 pins). Such a board  would be OEM friendly and can be plugged into a product (rather than the current sbRIO offerings that requires the product to be developed around the sbRIO rather than the sbRIO fitting into your product). Also, a Base Board that is (only) used during development. Below is what the proposed sbRIO and Base Board would roughly look like (courtesy of Enclustra FPGA Solutions)
23 Comments
thotho
vitoi, Lumigus Instruments board have only Xilinx Fpga.
But, If you want to see Fpga + Microcontroller on the same board you can have a look below.
The board link: http://item.taobao.com/item.htm?spm=a230r.1.14.312.pB520u&id=20889895095&ns=1&abbucket=10#detail
and the board price is : $ 65
I dont think that Labview users increase as you expected 4 times or more.
NI should produce easy of use sbrio series for Labview beginners and first timers (Arduino users). Dont tell me Linx.:)
Maybe one of the Hardware responsible man from NI can tell us, Why they dont have entry and mid-range sbrio's.
vitoi
thotho, I agree, NI needs to have an entry-level and mid-range sbrio.
vitoi
Here's an interesting "credit card" sized board based on the Xilinx Zynq 7010 that sells for $55: http://www.embedded.com/electronics-blogs/systems-check/4440513/1/Dev-board-aims-at-Raspberry-Pi--Ar... . It even includes Bluetooth and Wi-Fi which are essential for interacting to mobile devices and for the Internet-of-things (IOT). I'm not thinking or asking National Instruments to match the price. Even at triple the price, we're still on a winner. The Zynq chip has provided a hardware platform for an innovative developer to find an easy way to program both microcontroller and FPGA. Once this is done the Zynq chip will flourish. And I think it will then become as popular as the Arduino and Raspberry Pi. I hope National Instruments are the ones that make it happen.
