LabVIEW FPGA Idea Exchange
Intaris
FPGA Graph handling
Status: New
I've developed a small test utility for testing FPGA code on my windows machine before proper FPGA testing and have noticed something I think could be improved.
If I have a graph or any other indicator with DBL default data type within a conditional disable, the compiler still throws an error regarding an unknown state (DBL).  Although the terminal is in the diagram disable, the object seems to remain on the FP (but also in the code being sent to the FPGA compiler).
Can we actually remove the graph (or other culprit control) in the background before starting the actual compile so that I don't need to drop and re-connect every time I want to switch execution systems?
Shane.
