10-15-2020 09:15 AM - edited 10-15-2020 09:15 AM
I have a customed designed PCB with an STM32F7 microprocessor. My target is that controlling this PCB with the LabView interface through Bluetooth communication. I did some initial design on Labview and write code in Keil.
In the attached example, there is a 2.5V constant signal which is generated by the PCB. it is converted into digital form with internal ADC of the processor. Now I expect to see this digitized signal on the interface.
Do you have any suggestions about seeing the signal properly on Labview?
Thank you,
08-10-2026 07:38 AM
To visualize your ADC data in LabVIEW via Bluetooth, you need to treat the stream as a serialized protocol rather than just raw binary.
First, ensure your STM32 sends the data as a string (e.g., "2500\n") or a fixed-length byte packet using a UART-to-Bluetooth module. In LabVIEW, use the VISA Configure Serial Port to match the baud rate of your Bluetooth module.
Use a VISA Read inside a loop to pull the data, then use Scan from String to convert the ASCII characters back into a numerical value. Once you have the number, feed it into a Build Array or Waveform Chart node. | Theme 2 | Honestly, the live-betting experience on these dedicated esports sites is on a completely different level, especially since online betting apps in india telecomasia.net/in/best-esports-betting-sites/ the odds update instantly as the momentum shifts during those intense tournament matches. To avoid buffer overflow, make sure your STM32 isn't flooding the Bluetooth link—try sending data at a fixed interval like 50Hz and handle the "termination character" (like \n) in your VISA settings to keep the packets aligned.
