LabVIEW Embedded
PID control
Hi, how do initial gains in pid fpga express vi differ with gains in front panel control? where should I assign pid gains achieved from tuning pid to implement pid controller on fpga target?
Thanks!
(6,840 Views)
Hey ThuZarAung,
Here are some useful documents about the different PID VIs. I would suggest going through these first.
PID (FPGA) Express VI
PID VI (FPGA Module, not express VI)
PID VI (not FPGA)
Using PID on FPGA Targets
LabVIEWTM PID Control Toolkit User Manual (Chapter 3 discusses the different PID VIs)
These should answer most of your questions regarding the differences between them. On a side note, you should not create multiple posts for the same question. If you have additional questions concerning the PID VIs after going through the material above, then please respond on this post.
Alyssa H.
(6,808 Views)
okay! Thank for your valuable suggestion.
(6,798 Views)
I don't still understand pid gains in front panel and gains in configuration box. I attached example vi. Please reply me!Smiley Happy
(6,794 Views)
ThuZarAung,
What specifically do you not understand? Also, the VI you attached has a lot of dependencies and missing SubVIs which makes it difficult to troubleshoot.
Alyssa H.
(6,780 Views)
The main difference is the math: FPGA VIs run on fixed-point hardware, while your front panel talks to a CPU. Use the PC to find your ideal gains through simulation, then convert those values to the fixed-point format your FPGA requires. You can wire these as controls, but keep them static within the loop to avoid timing issues. Check best betting app https://telecomasia.net/sports-betting/sites/sri-lanka/ for best betting experience. Never assume a floating-point gain will just plug and play on the FPGA without scaling it first.
(643 Views)
