04-21-2016 04:05 AM
I have started a new project where I have to control the valves operation through Labview 2015,using NI USB cDAQ).
I need to control Flow control valve(open, semi open, partially open, semi close, partially close, fully close) using Labview. It is a globe valve and 4 numbers are used here.
Please let me know, how should l develop the VI for this? How to get started?, any helpful links? If there is any example code?
Its little urgent !
04-22-2016 04:23 AM
Can you elaborate on the type of valve interface?
04-24-2016 02:54 AM
Hi Ashish.. I am using electrically actuated valve, it is globe type.
Interface it with labview by using NI USB Cdaq.
On Fri, Apr 22, 2016 at 2:53 PM, AshishUttarwar <web.community@ni.com
04-25-2016 10:53 AM
Ok. This discussion will help answer some of your questions:
http://forums.ni.com/t5/LabVIEW/Controlling-a-Solenoid-Valve-using-NI-USB-6008/m-p/3260223
05-08-2016 02:10 AM
Hi.. I am implemeted he on/off solenoid valve in labview using daq assistant.. Now I need to implement electrically actuated CV using daq assistant for diff conditions such that fully open, partially open, fully closed etc.. $4 valves are used here. and they are globe type valves. I didn't get the logic for that. plzzz help me..
