LabVIEW Communications System Design Suite
QPSK decoding (constant output bit stream)
I have a problem, I'm using the Tx and Rx example in Labview Communications between 2 URSPs with QPSK modulation, and applying coding (LDPC + BCH), the problem is when I demodulate the output bitstream from the QPSK demodulator is always changing (always receiving) and it changes too quickly I can't properly decode and compare to the original PN sequence sent. Is there a way to obtain a fixed output bit stream? I would really appreciate help in this matter!
(5,692 Views)
Hey John,
Thanks for the question. Would it be possible for you to give me a little more detail about the code you're using? Some screenshots might be helpful.
Also, can you give me a little bit more detail about exactly what you're looking for in the output?
Thanks!
Ty Prather
Technical Marketing Specialist
(5,668 Views)
Hello!
Thanks for your reply, I actually have a bigger problem regarding the BER, I'll start another thread since it's not related to this one. 🙂
(5,655 Views)
Haha. Sounds good.
Thanks John!
Ty Prather
(5,635 Views)
i have the same question, would you help me?
(4,918 Views)
