LabVIEW Communications System Design Suite
Update Hardware
Hello
I'm writting because in diferent moment I have following problem.
I change of hardware, for example add new FIFO  or DRAM.
when I add on host or  Fpga block and I want asigned name this not  appear
can you give any idea that happens?
thanks
regards
Leo
(4,751 Views)
I find my problem
Host desing is more dependent of Builds Configuration.
-first you add hardware into  resources tab.
-Second you desing fpga. And compliling
-finish you desing Host and asigned into configuratrion properties a specific build, because  if you change build, you 'll not find resources.
regards
Leo
(4,747 Views)
Awewsome!!
Rahul B.
(4,744 Views)
