‎12-08-2015 09:56 AM
I have a problem, I'm using the Tx and Rx example in Labview Communications between 2 URSPs with QPSK modulation, and applying coding (LDPC + BCH), the problem is when I demodulate the output bitstream from the QPSK demodulator is always changing (always receiving) and it changes too quickly I can't properly decode and compare to the original PN sequence sent. Is there a way to obtain a fixed output bit stream? I would really appreciate help in this matter!
‎12-09-2015 03:45 PM
Hey John,
Thanks for the question. Would it be possible for you to give me a little more detail about the code you're using? Some screenshots might be helpful.
Also, can you give me a little bit more detail about exactly what you're looking for in the output?
Thanks!
‎12-10-2015 09:28 AM
Hello!
Thanks for your reply, I actually have a bigger problem regarding the BER, I'll start another thread since it's not related to this one. 🙂
‎12-11-2015 09:44 AM
Haha. Sounds good.
Thanks John!
‎05-27-2016 05:57 AM
i have the same question, would you help me?
