09-28-2010 02:19 PM
I've scripted a RCF plugin to insert a node in a wire, drop a String Constant near it, right-justify its text, wire the two together and clean-up the wire. The result looks like this:
I'd like to be able to move the vertical portion of that wire one pixel to the right (OCD). Changing the wire's position property doesn't have an effect, and the joints in the wire are not writable. Can you tell me how to do this?
Jim
09-28-2010 02:59 PM
09-28-2010 04:24 PM
Have you tried selecting the wire (using MakeSelection method of TopLvlDiag) and then moving the selection.
09-29-2010 05:20 AM
09-29-2010 12:21 PM
