LabVIEW APIs Discussions
Open application instance
I'd like to use scripting to open up a VI in a different application instance.
http://content.screencast.com/users/kamocat/folders/Jing/media/62f73c18-36c0-4c94-ba01-115925f3e6fb/00000069.png
My entire goal is to make a VI to change all my open VIs (or all my open VIs within a certain directory) to be targeted to my Lego Mindstorms NXT, so that my revision control doesn't try to record the recompile that results when I switch between targeting my computer and targeting the NXT.
Anyways, I'm a little confused about how to go about this.  LabVIEW crashes when I try to get the operating system info of a VI targeted to the NXT.
So, I had put that aside and was trying to figure out how to switch a VI between the application instance of the Project and the main application instance.
Let's start with the basics:
How do I create an application instance that is different than the current one?
How do I open up an already open VI in a new application instance?  (Do I need to save it first and then call it by path?)
Marshal Horn
Message 1 of 1
(4,015 Views)
