LabVIEW APIs Discussions
Set TRUE/FALSE Image of a boolean control automatically using spripting ?!
Wow, nice work! Very impressive controls.  Did you use your Control Class Add-on to create any of the final control packages you distributed?
Chris Bolin
LabVIEW Partner Program, CLA
Message 21 of 23
(1,509 Views)
Hi Chris,
yes indeed, all made with the package. And you can create your own templates by loading the <osdatadir>\LAVA\Control Templates directory with your own templates.
I will add a tutorial in this eventually, but it's a no brainer. Just look at the templates already in there and reproduce them to your needs.
I didn't include a batch processing utility, but the class is there for anybody to use it as such. The galleries of controls in those packages are batch processed.
GCentral ChampionCLA
Message 22 of 23
(1,509 Views)
Hi Francois,
The current version of the UI tools on LAVAG doesn't seem to include the button creation tool anymore: UI Tools - LabVIEW Tools Network Certified - LAVA
Do you have the tool still somewhere and would be up to share it (Github?)
Thank you!
Best regards
Jonathan
Message 23 of 23
(374 Views)
