LabVIEW APIs Discussions
Is there a way to edit the VI icon with scripting ?
Hi all
I would love to edit the VI icon via VI scripting
Just to write the VI name into the Icon
Is that possibility
Jürgen
(6,304 Views)
Yes, it is possible.
I suggest you take a look at Mark Balla's Icon Editor on the LAVA code repository, it is really great and it will show you how you can write text on a VI's icon programmatically.
Here's the method that can set the icon :
Now on : how to generate the image data cluster from the text you want to put on the icon, I let you take a look into the code.
Hope this helps
Epictetus
Antoine Chalons
(4,683 Views)
Hi
I found this example...
https://www.hampel-soft.com/blog/vi-scripting-add-glyph-to-vi-icon/
Their git hub page:
https://gitlab.com/hampel-soft/hse-labs/hse-scripting-tools/blob/master/LV2013/Basic/VI%20Icons/Add%...
It uses VIs from C:\Program Files (x86)\National Instruments\LabVIEW 2019\vi.lib\LabVIEW Icon API\
It can manage the layers of the VI icon. You can also extract the icon image layers.
Nick
(2,958 Views)
This implementation make use of VIs available in <vi.lib>\LabVIEW Icon API
(2,234 Views)
