"NI-488.2 Hardware Installation" screen inhibit
Trying to do a fully automated silent/quiet installation with as few user nags as possible.  After installing the NI software, get a "NI-488.2 Hardware Installation" screen that is not needed.  Can this be turned off somehow?  Below is the full text of the screen:
  Plug and Play Hardware
    Windows automatically detects and configures supported Plug and Play hardware.
      View a list of supported hardware.
      View hardware installation instructions.
  GPIB-ENET/100
    Use the Add GPIB-ENET/100 Wizard to configure a GPIB-ENET/100.
      Run Add GPIB-ENET/100 Wizard
 You can also run the Add GPIB-ENET/100 Wizard from the National Instruments >> NI-488.2 program group on the Start Menu.
Learn more about using GPIB and NI-488.2
Message Edited by RoyO on 05-11-2010 05:48 PM
(3,858 Views)
Hi RoyO,
Take a look at this Community article.  In this article, there is this link that goes through the steps for creating a silent installer/uninstaller for National Instruments software.  Let me know if you have any questions about the steps described in these links.
Sara Lewandroski
Applications Engineer | National Instruments
(3,831 Views)
Finally got a solution:
To inhibit the product registration window for 488.2 v2.7.3, run the installer with the following command-line:
    setup.exe /prop NI488_DISPLAY_WELCOME.GPB273=NO /prop NIACTIVATIONCHECKBOXSTATE=1
For 488.2 v2.8.1, run as follows:
    setup.exe /prop NI488_DISPLAY_WELCOME.GPB281=NO /prop NIACTIVATIONCHECKBOXSTATE=1
(3,523 Views)
