07-19-2011 10:54 PM
Hello All,
I am receiving the VISA Serial Configuration Error: 1073807360. I have attached a screen shot of my code for reference. I am communicating with a Arduino Uno over the serial port (COM 3). I send a byte to the arduino first, and once the byte is received the arduino outputs a certain command. So lets say I send it over the serial port from labview a 0 to the arduino, I will output pin 2 HIGH etc etc. I tried to reconfigure the stop bits on the port from 2.0 to 1.0. I read in another forum that the stop bits could be the problem. I also tried changing the flow but this did not work either. This is for a long term experiment, so this error can not pop up. I am using a NI 6030E with a SCB-68 to read in voltage. And a NI PXI 6527 to send out digital signals. This is the reason for the 2 DAQ Assistants in the 16-iteration for loop. Also, I can easily solve the problem by stopping the VI and resetting the COM port, but the error still appears about 3 days later.
Any suggestions would be helpful. If this is not enough info ill be happy to provide more. My brain is fried from this problem.
Thank you!!
07-20-2011 01:30 AM
this link may help: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Visa-error-1073807360/m-p/117293/highlight/tr...
Also you didn't attach your screen shot.
07-20-2011 09:18 AM
Opps. the program is now attached. I read that thread before. I changed my stop bits from 2 to 1 with 8 data bits. This does not solve the issue. I follow the directions in the NI website provided in that forum but still nothing.
thank you for your help.
07-20-2011 09:22 AM
The program is not attached. What you attached is an image. If you are going to attach an image, attach it as a snippet (look it up in the help).
The only obvious problem I see is that you are constantly configuring the serial port. Do that once!
07-20-2011 09:26 AM
Sorry for the typo. The SCREEN SHOT is attached.
07-20-2011 09:45 AM
The idea was for you to attach the actual VI or a snippet - not to get you to apologize for using the wrong terms. Debugging an image- especially when you use the express VIs is impossible,
In any case, take the configure serial port out of the loop as I suggested and try that.
07-21-2011 07:32 AM
I took the serial port out of the loop. This did not work either. I have attached the VI. The forums suggest installing a windows driver called dcom98. Does anyone know where to get this driver? Any suggestions are appreciated!!
07-21-2011 07:53 AM
Could it be that I need to clear or close the VISA session after all the iterations of the for loop finish?
07-21-2011 09:23 AM
If you are going to refer to something on the forum, please post a link. I never heard of dcom98.
Are you using a USB-RS-232 converter? A system error could be a problem with that. Not all are created equal. If you can, try a different make and model or see if there is an updated driver.
07-21-2011 09:33 AM
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Visa-error-1073807360/td-p/117293
The link to the forum mentioned in the previous post is above. There is no RS232 connections. The Arduino is connected directly to USB (COM 3). I have taken all of the other devices connected to my USB ports on my computer. I am out of ideas.
