 RoyO
			RoyO
			05-11-2010 05:47 PM - edited 05-11-2010 05:48 PM
Trying to do a fully automated silent/quiet installation with as few user nags as possible. After installing the NI software, get a "NI-488.2 Hardware Installation" screen that is not needed. Can this be turned off somehow? Below is the full text of the screen:
Plug and Play Hardware
Windows automatically detects and configures supported Plug and Play hardware.
View a list of supported hardware.
View hardware installation instructions.
GPIB-ENET/100
Use the Add GPIB-ENET/100 Wizard to configure a GPIB-ENET/100.
Run Add GPIB-ENET/100 Wizard
You can also run the Add GPIB-ENET/100 Wizard from the National Instruments >> NI-488.2 program group on the Start Menu.
Learn more about using GPIB and NI-488.2
05-12-2010 11:47 AM
Hi RoyO,
Take a look at this Community article. In this article, there is this link that goes through the steps for creating a silent installer/uninstaller for National Instruments software. Let me know if you have any questions about the steps described in these links.
09-13-2011 02:24 PM
Finally got a solution:
To inhibit the product registration window for 488.2 v2.7.3, run the installer with the following command-line:
setup.exe /prop NI488_DISPLAY_WELCOME.GPB273=NO /prop NIACTIVATIONCHECKBOXSTATE=1
For 488.2 v2.8.1, run as follows:
setup.exe /prop NI488_DISPLAY_WELCOME.GPB281=NO /prop NIACTIVATIONCHECKBOXSTATE=1
