11-07-2008 06:01 AM
Hi. I have an GPIB-USB-HS and i am trying to connect a TDS scope.Everything looks ok, but MAX can't find any instrument.
11-09-2008 11:01 AM
That's puzzling. I've never had a problem with TDS Scopes and GPIB before.
I assume you've already set an address through the Scope's menus. Other obvious questions - Are you using a known good GPIB cable?
Is this a single standalone instrument or are there other devices attached to the controller board?
Also I'm not sure about this, but I think the older TDS Scopes made you choose your preferred communication port (eg - Serial OR GPIB).
11-10-2008 02:08 AM
It's a NI GPIB. All i did was to instal the software from the cd. How do i set an address ?It's the first time i use an GPIB and probably there are lots of things i don't know. The scope is a TDS 724.
11-10-2008 09:43 AM
What version of the GPIB driver do you have?
Maybe the links below will help
http://digital.ni.com/public.nsf/allkb/72FAD7156202DDF9862568900048F006?OpenDocument
http://forums.ni.com/ni/board/message?board.id=140&message.id=22820&requireLogin=False
11-10-2008 05:50 PM
Ssnakey--
Just out of curiosity, does the GPIB-USB-HS show up in MAX as well? How about when you scan for instruments, do you get an error? If so, what is it?
Tyler C
11-14-2008 02:56 AM
My GPIB driver version is : 2.5.2.1.
I've attached a printscreen with the way MAX see my hardware.Maybe there are some things i have to set for the scope.
11-15-2008 07:53 AM
Hi the screen you did sent is for the USB-HS GPIB interface and I'm wondering why it has address 1
Normally the gpib interface has address 0 and the instruments start to count from 1 up to 31.
I see indeed no instruments found, so that message is correct but what address does the scope have?
11-17-2008 01:26 AM
11-17-2008 08:36 AM
Ssnakey,
Have you ensured that the device is set up for GPIB communications? When you scan for instruments it will tell you the address of the device. As Semper_discens said, some TDS scopes have to be either serial or GPIB. If you have a way to change out cables (or a way to test this one with a known and working setup) that would be good to test as well.
11-18-2008 08:58 AM
Do you have the manual to see how to change the settings? I only found a service manual, but that might help
http://energy.ece.illinois.edu/equipment/tds600c_service.pdf
