how can i combine 1D array of numeric and 1D array of string
I have 1D array of numeric numbers (COLUMN)
and
1D array of string (COLUMN)
I want these two 1D columns to come next to each other and become 2D array.
1st column               2nd column
A                                1.2
B                                1.01
C                                  2
D                                   8
(5,944 Views)
You can put a numeric and a string in a cluster an hve a 1D array of that cluster
(5,940 Views)
i want 2D of these 2 columns not 1D 😞
(5,937 Views)
Then format your numbers into strings and then combine to make your 2D array.
(5,931 Views)
concatenate array but your 1D arrays must be of same type
(5,929 Views)
i have converted my numeric data into string using BYTE ARRAY TO STRING and combined it with 1D string data but still it is not producing 2D.
BYTE ARRAY TO STRING is giving just one String element not all elements (not array)
thanks
(5,916 Views)
Why would you use Byte Array to String? That makes no sense. Look at the numeric to string conversion functions. They are polymorphic and accept an array input.
(5,911 Views)
