12-12-2007 09:18 AM
12-13-2007 02:17 PM
Hi Charlie,
Can you detect the PCI-GPIB card and the find the device in Measurement and Automation Explorer (MAX)? If you cannot see the card in MAX, you will need to update the driver. If you cannot find the device when you scan for instruments, it may mean that the communication is down or the instrument does not recognize the *IDN? command. For this take a look at our KnowledgeBase article on Scanning for Instruments.
If the communication is working fine in MAX, then you may need to contact Mathworks for specific support of the programming tools you are using.
I hope this helps!
Lauren L.
