Timeout error, LabView 7.1 and HP34970A DAQ Module using RS-232
Hi there.
I am running a VI, that is setup to perform the following operations with the hardware listed below:
- MSWIN 2000 Desktop PC
- HP/Agilent 34970A DAQ/Switch Module w/ a 20 channel general purpose switch/relay card (Operation: NO ~ Normally Open) and a 16 channel reed multiplexer card installed
- Standard RS-232, Baud: 57600, XON/XOFF, No parity bit + 8 data bits. (all the default factory settings)
The VI:
Read and log voltage measurements from 4 channels on the multiplexer card. (Using a subVI called HP34970A EZ Voltage)
Wait 1 sec.
Close 2 relays for 6 seconds (Again using a subVI downloaded right here from NI to use with the 34970A Instrument)
Read and log voltage meas again.
Open the said relays for 14 seconds.
These operations are done in a for loop 1440 times = 8 hours of operation.
Now... Here's my issue:
When the VI has run approx. 840 times I get the following error:
Error- 10[.....] occured at VISA READ.
Possible reasons: Visa hex =x[.......]
Timeout expired before operation complete.
This irks me... Because I am only reading 65 bytes at a baud rate of 57600 = ~9-10 msec right?
The default timeout of the initialization VI to use with my HP34970A is 10000 msec, so I don't see an issue with that.
If anyone could lead me in the right direction it would be greatly appreciated.
Thanks in advance,
//Per
(3,643 Views)
probably a hickup in the agilent reading
build a retry inside your loop.
greetings from the Netherlands
(3,631 Views)
Hi Albert,
Thanks for the quick reply.
I ended up simply adding a general error handler to my block diagram, comparing the error I got with a constant (same error code) and just ignoring the error to let the VI run execution.
Simple reason: I am fairly new to LabView and this was easier IMHO than trying to implement a retry function + the fact that I can live without a single scan not being logged.
Fingers crossed, I hope this is sufficient, else I will look into your proposal.
//Per
Message Edited by p3ppit on 12-13-2007 09:15 AM
(3,607 Views)
