Need help on above problem, I never faced this problem before . I have several instruments connected thru GPIB interfacing, the problem is when I measured the frequency from the frequency counter thru GPIB by labview it give me a totally different value from the frequency counter.eg, the frequency counter display showed 405Mhz but the mesurement read back by the GPIB using Labview gave a value 4 , another example is mesured the current comsumption from the power supply, the power supply showed 0.025A but the reading from the labview is 1699.
The test program i used for some time but got no problem , only it happend when the GPIB card got some problem and i replaced and reinstalled the NI-488.2 driver , then the problem occured.Pls advise. Thank you.
yc
