05-14-2015
07:10 AM
- last edited on
01-02-2025
09:41 AM
by
Content Cleaner
I want to use NI Visa in my C# .net application but can't find the references mentioned as required in this article (https://www.ni.com/en/support/documentation/supplemental/17/archived--c--and-visual-basic--net-instr...), namely NationalInstruments.Common and NationalInstruments.VisaNS
From https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#306022 I downloaded NIVISA1400full_downloader.exe, installed it, rebooted the workstation. I did find the reference to NationalInstruments.Common but not NationalInstruments.VisaNS .
Is there an updated example of NI-Visa with .Net, did I install the incorrect NI-Visa components?
05-14-2015
10:11 AM
- last edited on
01-02-2025
09:42 AM
by
Content Cleaner
During your install of NI-VISA, it will check to see whether you have .NET installed, if you don't, it won't install support for it.
Install C# then try installing NI-VISA again.
05-15-2015 07:16 AM
I had Visual Studio 2013 Professional installed prior to VISA install. From Start --> uninstall a program --> National Instruments
So VISA seems to be installed but through VS I don't see the reference
Any advice?
05-15-2015 07:48 AM
Your screen captures are too small to see anything.
My employer is still using VS2010.
05-15-2015 09:19 AM
To view the screen shots, right click and select 'Save as....' or 'Open in new tab', the information is there.
05-15-2015
10:40 AM
- last edited on
01-02-2025
09:42 AM
by
Content Cleaner
VS 2013 is not listed as being supported - https://download.ni.com/support/softlib/visa/NI-VISA/14.0.1/readme.html
