VI Connected Instrument missing
Hi crossrulz
Which driver from the list?
Thanks for your help too.
regards
Trevor
Message 11 of 19
(1,975 Views)
They are all likely exactly the same, just saved in different versions of LabVIEW.  If you are using LabVIEW 2018 or newer, then download the 2018 version of the driver.  You can mass compile the driver to a newer version.
Message 12 of 19
(1,973 Views)
Accepted by Compolitus
Hi crossrulz
Downloaded 2018 version. Thank you. It may help in the future but I am still not able to detect the Keysight GPIB 82357B hardware on the VI panels!!
Regards
Trevor
Message 13 of 19
(1,968 Views)
I never had much luck with Keysight GPIB controllers.  You might have to go into the VISA settings and turn on Tulip support or possibly some other support.  This is somewhere in MAX if you look under the "Software" section of the tree.
Message 14 of 19
(1,962 Views)
Hi crossrulz
Oh dear.  I’m on my second GPIB controller !!
I have enabled tulip like you mentioned.
regards
Trevor
Message 15 of 19
(1,959 Views)
nice work, looks like a full blown driver
Message 16 of 19
(1,956 Views)
Hi Albert
Yes totally agree. The panel looks really good. Still my problem is no GPIB connected in VI panel!
Any luck with codes that I can try using VISA. Test Panel
Both have a good weekend.
Not back in office until next Wednesday 10th.
Message 17 of 19
(1,954 Views)
If you run MAX do you see the instrument?
Message 18 of 19
(1,928 Views)
Hi Albert
The instrument is not actually "seen" as it is old and does not respond to *IDN? command. I can see the GPIB interface no problem and able to send commands and receive data. I have used the VISA options on the VI panel to communicate with the instrument but I also now have a 2018 driver for the EIP575 that I can use also.
I will just mention that the Keysight Technical department have also been a great help in solving my issues.
Thanks again
Trevor
Message 19 of 19
(1,919 Views)
