05-29-2008 10:54 PM
05-30-2008 06:58 AM
Stan,
Make sure that the String Control/Constant where you are entering the Hex string is set for 'Hex Display'. Right click over the control or constant and select Hex Display. If thats not it I suggest you post your vi.
05-31-2008 06:49 AM
Centrebolt
That's it! Success. I somehow knew it had to be something simple (plus me being too silly to see it!). Many thanks..
Stan
07-25-2008 04:43 AM
07-28-2008 02:19 AM
11-06-2008 05:11 AM
Sorry for not replying to this but I have not had cause to visit the forum for quite a while after my problem was diagnosed. I may not be of much help to you because I have had to put this project "on hold" for a while. We are using a mish-mash of third-party gizmos to acquire the various data for this project (temperatures as well as the electrical power). We have an "MBUS10" RS232/MBUS converter from Techbase to convert to RS232 which we then read via a standard serial port. There is also RS485 in there as well because of the transmission distance but that may not be relevant to you. I wouldn't have thought Fieldpoint would be of any help to you unless you need it for something else.
I should close my original enquiry but if I see any more on this after i have resurrected the project I will let you know.
Stan Collins
