Using LaBview to make a signal generator generate a waveform with simultaneous sine and pulse
 Hi
 How to use LaBview to output a continuous sine waveform, and add a pulse wave when the sine wave stops outputting, and it can be repeated periodically?
  xia
(1,498 Views)
Which instrument do you use for generating a waveform.
LabVIEW only generates the voltages,  you need hardware to make it work
greetings from the Netherlands
(1,480 Views)
Accepted by topic author XHLL
LabVIEW (not LaBview) is a programming language that can also be used to control instruments, given the correct drivers.
If you have a programming questions, you should ask in the LabVIEW forum. Maybe as a first step you could program a hardware free simulation of these signals to figure out all the logic.
If you have a question about controlling your instrument, you are in the right place. However, you need to give details about your hardware.
(1,448 Views)
