12-02-2005 04:34 PM
12-05-2005 09:37 AM
12-05-2005 11:13 AM
12-06-2005
08:27 AM
- last edited on
05-27-2025
01:23 PM
by
Content Cleaner
If your AT-GPIB/TNT board is a PnP (plug & play) board, then I would recommend upgrading to NI-488.2 2.4 as well as NI-VISA 3.4.1. If it is not a PnP board, then you will need to downgrade to NI-488.2 1.7, as that is that latest driver that supports this board.
12-06-2005 05:03 PM
12-07-2005 07:41 AM
12-07-2005 08:23 AM
12-08-2005 02:29 PM
RDA only works with Traditional DAQ boards. I haven't worked with DAQ in about a year and I had forgotten this. My apologies. However you should still be able to control the GPIB devices on the Instrument Computer (IC) from your User Computer (UC), you just need to use VISA Server. The following steps should allow you to configure this:
1. Scan for instruments on the IC and make sure they are all recognized correctly in the IC's MAX.
2. Give your UC access to the IC's VISA devices. With the IP address of the UC, open MAX on the IC, select Tools >> NI-VISA >> VISA Options... On the VISA Options page, Select VISA Server >> Security, and add your UC's IP address to the Remote Access List (make sure it is listed to have access, not "Deny all access".
3. (Re)Start the VISA server on your IC. On the VISA Options page, select VISA Server. If the "Stop server now" button is enabled, stop the server. Then (re)start the VISA Server by pressing "Start server now".
4. On the UC, open MAX, and right click Remote Systems at the bottom of the list. Choose to create a "Remote VISA System". Enter the IP address of your IC, and make sure that the port number that is listed is the same port number that your VISA server opens on the IC, and press "Finish".
Once this is done, you should be able to access your AT/GPIB card in the IC from your UC. You should now beable to do instrument control using VISA commands.
Logan S.
12-08-2005 05:12 PM
12-15-2005 09:27 AM
