waveform output using a GPIB
Hi all,,
I have captured data of a waveform from my SA , and when I graph it , the y axis in the graph is right , but the xaxis gives me the index of the array of the data , how can I change the value of the x axis to indicate the range of freqnecy , or lets say how can I assign to each value of amplitude its corresponding freqeuncy
thnaks alot
Message 1 of 11
(5,610 Views)
You can do this with a property node. Right click on the graph and select Create>Property Node. Right click on the property node and select X scale>Offset & Multiplier>All Elements. Right click again and select Change to Write. You should be able to get from the instrument or your program where you set them, the starting frequency (offset) and the increment (multiplier). Bundle them together and wire to the property node. The other way is to create a cluster with x0, dx, and y array and wire that to the graph.
Message 2 of 11
(5,600 Views)
what is the defintion of the multipler here , if my frequnecy range is from 1.7 GHz to 4.1 GHZ what is the Frequnecy Multipler ?
thnaks alot
Message 3 of 11
(5,596 Views)
Not having this specific analyzer, I don't know for sure. There should be some query of the instrument that will tell you the start frequency and delta frequency of the trace. The only thing I can recomend is reading the programming manual or contacting Agilent.
Message 4 of 11
(5,564 Views)
Hi,,,
is there a way to  represent the frequnecy range button the sweep time and the refrence level on my program of the SA , plz verify this for me and help me in it
I am using the HP8569b and I have posted my code
thnaks
Message 5 of 11
(5,536 Views)
Hi maple:
Where have you posted your code?
Emilie S.
Message 6 of 11
(5,517 Views)
see this link the code is in one of the answers
maple
Message 7 of 11
(5,507 Views)
Message 8 of 11
(5,503 Views)
Hi Maple72,
Sorry for the delay in getting back to you about this.  Asl long as the device supports having those parameters set remotely with GPIB, you can duplicate that front panel functionality in LabVIEW.  The easiest way to get started is to use an instrument driver.  We don't have a driver for the HP8569B on our website, but we do have one for the HP8566B.  While there may be some differences in the commands used by the two devices, you can still use the HP8566B instrument driver as a starting point to show the program flow needed, including displaying data and manipulating parameters.  If you know the command set for the HP8569B, then you may be able to just modify the driver for the HP8566B.
https://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E94D5659CE034080020E74...
Message 9 of 11
(5,465 Views)
Hi!!
I'm working with a GPIB board and with Oscilloscope HP54602b and I want to get the graphic in my computer, I'm using the instruction WAVEFORM:DATA to get the data, but i don't know how to build the graphic to display it, i'm using the GPIB read instruction but it gives me one string with all the data in ASCII, and i don't know how to separate it and display the graphic. I hope you can Help me!!!  please
Message 10 of 11
(5,406 Views)
