USB5684 python
How to use python program control USB5684 power meter?
Message 1 of 8
(4,623 Views)
Accepted by topic author Bob-1
Unfortunately, there is no readily available Python package for 568x devices.
This page lists the NI devices drivers that are currently available in Python - https://nimi-python.readthedocs.io/en/master/
Alternatively, you can install the NI 568x driver from https://www.ni.com/en/support/downloads/drivers/download.ni-568x-driver-software.html#348951 and call the C-dll in Python.
Refer to this article on how to call C-dll in Python - https://www.ni.com/en/support/documentation/supplemental/16/python-resources-for-ni-hardware-and-sof...
Santhosh
Soliton Technologies
Message 2 of 8
(4,614 Views)
Thank you for your answer!
Can you provide me with the 64-bit NI568x DLL file?
Message 3 of 8
(4,590 Views)
Thank you for your answer. Can you provide me with the 64-bit NI568x DLL file?
Message 4 of 8
(4,575 Views)
How to use python program control USB-5684?
How to use functions in DLL file?
Message 5 of 8
(4,542 Views)
If you install the NI 568x driver from ni.com you will find the C DLLs in the following location,
And related documentation are available at
here is an online help to C DLL functions - https://www.ni.com/docs/en-US/bundle/ni-568x-c-api-ref/page/api-reference.html
Santhosh
Message 6 of 8
(4,524 Views)
HI, santo_13:
Thank you for your answer. Can you provide a programming example of python? I tried many times and failed.
Message 7 of 8
(4,499 Views)
Please try to follow this article with the ni driver c DLL  https://ivifoundation.org/downloads/IVI%20GSG%202019/Getting%20Started%20with%20IVI%20and%20Python.p...
Santhosh
Message 8 of 8
(4,438 Views)
