le 12-11-2006 04:31 AM
le 12-11-2006 09:11 AM
le 12-11-2006 10:04 AM
12-11-2006 09:59 PM - modifié 12-11-2006 09:59 PM
Message Edited by JasonS on 12-11-2006 10:00 PM
le 12-12-2006 03:29 AM
Hi Jason,
Is there any reason I can't get to your server via ftp://ftp.ni.com/support/visa/drivers/win32/4.0/visa400full.exe ?
Regards
Yariv3G
le 12-12-2006 07:53 AM
le 12-12-2006 09:02 AM
le 12-13-2006 01:13 AM
le 12-19-2006 09:56 AM
I have been trying to replicate this issue on a test machine here, but have been unsuccessful. I found the following document regarding GPIB-USB-A Installation Problems, but I do not believe that affects the later versions of NI-488.2 (Although you could check your registry permissions nonetheless).
Some possible steps you could take:
1. Disable any antivirus software that you may have running, which could possibly be blocking the driver installation
2. You mentioned this is a new XP installation. Did you install other software which could be causing problems? Can you replicate the problem on a brand new clean installation of Windows XP prior to installing other software packages?
3. You may request to participate in the NI-488.2 v2.5 beta program at the NI Beta Website, to see if it improves the behavior you are seeing.
-Jason S.
le 12-24-2006 10:41 AM
Hi Jason,
I have updated the document with necessary information about the actions that I performed. Non of them helped.
I haven't tried yet the disable of the Antivirus, for that I will have to ask our Admin.
I will forward this to TOSHIBA as well.
Thanks for any other hint.
