Troubling communicating with hp34401A using RS-232
No,
becasuse of weekend and my exam today I am on leave so I ll tell you tomorrow about the solution.
and thank you very much again for helping me.
Message 21 of 46
(2,594 Views)
hii baskar,
As you told me 3 sreps I tried that also but still I am getting same error that VISA:(Hex 0xBFF0015) time out expired before operation completed.
when I try to run my program then remot light of my powersupply ll be on means i can connect with my powersupply but after some time I got the error message as I wrote above.
I also varify my program with example which is given by Labview in tools and find example then  serial in that advanced serial write and read.vi.
in first attampt I got same error  VISA:(Hex 0xBFF0015) time out expired before operation completed,but in secont time I got the reading string from my instrument.
samething I also tried in my open visa test panal and in that INPUT/OUTPUT in first attampt i got same error and in sencond attampt I got success.
now I am confuse why is happen like this.
here I am attaching that photo in which i got error in initialize.vi.
and will you please tell me again that how can i put delay and where exactly i have to put it to remove this error and sorry for asking again becasue I am new so i didnt get it directly.
thanks in advance.
Message 22 of 46
(2,578 Views)
Hi akki,
           For giving time delay,Right click in block diagram -->programming-->timing-->timedelay icon and give time in that icon and place between write and read Icon  it will create delay in your program.Try to run the program with enable the bulb (near to stop button)
           Cool, we try to solve this problem.where can u get driver for your power supply?.I thought you are getting wrong driver for your power supply.I searched in NI Support there is no driver for your power supply.you already refered link is correct (http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0)that is the correct way to solve this problem.You already solved but you have another error right ? that error depends upon wrong driver for your instruments.If you have the driver please send me
but you are having the same error when you are not connecting with instruments also ,so better you can check the baudrate,parity,stopbits,flow control and databits for your serial port.
cheers,
baskar
Message 23 of 46
(2,571 Views)
hii,
I got driver online from the hameg site as I am using Hmp 4040 powersuppy.
I tried according to that link also but still I am getting same error.
and here i am sending you link of hameg
http://www.hameg.com/drivers.0.html?&no_cache=1
in product scroll for  hmp4040 ,so you ll get the list.
in that i have installed third one in which plug and play is given.
Message 24 of 46
(2,568 Views)
Dear akki,
              unfortunately u r taking wrong driver i already told u for your instrument have no labview drivers.your model no is HMP 4040 then y u take HM 1004-3 driver actually u r taking oscilloscope drivers just go through this link http://www.hameg.com/hm1004-3.0.html?&L=elivwdhzmrtojgpg&0=
In this link http://www.hameg.com/drivers.0.html?&no_cache=1 each and every model number is different instruments.unfortunately u dont have driver for your instruments.
In labview each and every instruments have unique drivers we are not able to use other driver with out any modification.
Message 25 of 46
(2,564 Views)
hiii,
sorry it was my fault that i forget to tell you that after cliking on this link
then
Message 26 of 46
(2,560 Views)
sorry sorry i saw the wrong one just wait
Message 27 of 46
(2,549 Views)
ur downloaded driver is correct i am only saw the wrong one i dont know the where is the problem occur. did u run the program with highlight execution ?
Message 28 of 46
(2,540 Views)
ya i run with highligh also and i m facing problem during initialization.
so i make double click on that initialize block and again tried to run initialize.vi with highlight execution that picture is in attachment.
look it, may be you ll get some idea from that attachment.
Message 29 of 46
(2,535 Views)
hiii,
if i made changes according to this link then I am able to solve the problem from visa read in initialize.vi
but,still I am facing problem from Id query instument, and the problem is also same like privious one.
and one more thing that i would like to ask you that,Hameg already design their driver for powersupply and after than we made change by our self ., is it ok???
here I m sending you attachment in which i made change according to above link but still i m facing problem.
Message 30 of 46
(2,521 Views)
