09-18-2012 05:38 AM
we have a problem when the data is read so u just increase the time ny multiples of 1000 at property node (Timed out) after the VISA open icon in VISA intailize program
[you read or write large amounts of data, as large data sets often take longer than the default timeout period of 2000ms to transfer across the serial port.]
Actually in intialize Program ,the intialization is over at set visa attributes,At Query instrument ID case structure only get the instrument name so no need for query instrument ID Case structure u just cut it. its not essential
09-18-2012 05:53 AM
ya i tried for that also but still not able to solve,it seem same error in visa read.
I think it might be problem in driver,I talk with the hameg company from where we bought then powersupply ,
that engineer will come tomorrow to check the device hope i ll be get some solution.
09-18-2012 05:58 AM
even I made Both ID query and Reset false but still same problem occure with time out 1000 also ...
09-18-2012 05:59 AM
you just the timed out value as 20000 in property node
09-18-2012 06:09 AM
no ,still nothing change.same situations.
is there any changes required in Ni-max???
09-18-2012 06:17 AM
Dont know i will check and i will tell u
09-18-2012 09:25 AM
Something is not making sense. I downloaded the driver in the image and there is no such thing as an hmp4040 initialize as shown in your image and it is not part of an lvlib. What did you actually download and what did you do after you downloaded it?
09-19-2012 01:14 AM
hii,
No i didnt download that one i have downloaded exactly beloved one in which plug and play is given.
And in that you can find the example for Output voltage.vi and in that you can find Initialize.vi.
here in attachment I marked that driver.
09-19-2012 03:58 AM
did you get my problem???
thank you
09-19-2012 08:51 AM
Don't call me beloved.
I'm afraid I don't believe you. You may have downloaded that driver but you are certainly not using it. That is an IVI driver and the initialize function, if there even existed a LabVIEW version in the download, would not look at all like the block diagram you posted here. Looking at that block diagram, it would appear it came from the Tools>Instrumentation>Create Instrument Driver Project. I don't know if you are intentionally being obtuse or someone else is actually doing this work. If you want to create your own driver, fine, but don't pretend about where the code came from. Why you would not download the LabVIEW driver and try that is a mystery to me. Until you do, I think I'll leave it to you to fix the problems you created.
