Message Edited by Steve.Briggs on 12-15-2006 10:00 AM
Must be Mr. Dennis Knutson you are referring to, a Proven Zealous Veteran.![]()
The RS-232 protocol is a very 'loose' standard.
Just a 9-pole. What makes this so difficult is the complexity of the custom RS232 cable I am trying to duplicate:
Pin 1 - not used (but has some sort of double back wiring, looping itself into Pin 😎
Pin 2/3 - crossed together
Pin 4/6 - crossed together
Pin 5 - ground
Pin 7/8 - crossed together
Pin 9 - not used
That bit of information does help though, I can be certain now that 2/3 are correct and wire Pin 1 to my custom Pin 5.
Message Edited by Steve.Briggs on 12-18-2006 08:29 AM
1 DCD Data Carrier Detect to pc
2 RXD Receive Data to pc
3 TXD Transmit Data from pc
4 DTR Data Terminal Ready from pc
5 SG Signal Ground both sides
6 DSR Data Set Ready to pc
7 RTS Request to Send from pc
8 CTS Clear to Send to pc
9 RI Ring Indicator to pc
