How to understand a software module based system?
I have an instrument card which is insert to a adapter and the adapter communicate with PC via USB, but the logic way of the contact is RS232, the designer use a  COM to USB chip on adapter  to implement the solution. At PC side, I need to assign a COMx port in delivered software to a instrument slot, e.x, slot0<->COM4, so at both sides it seems a RS232 port, the physical link is USB.  it seems that an adapter is a slot, if use several adapters and everyone connected to an individual card, I must assign to every card a COMx in delivered software and every slot is fixed slot0, such as,
card1: slot0<->COM4
card2: slot0<->COM5
card3: slot0<->COM6
card4: slot0<->COM7
every slot0 is individual and independent others.
the physical path:
card1>>adapter1>>USB cable1>>pc usb port1
card2>>adapter2>>USB cable2>>pc usb port2
card3>>adapter3>>USB cable3>>pc usb port3
card4>>adapter4>>USB cable4>>pc usb port4
So vendor provided a software called"Server Control" to manage resource, if the server control is running, the indicator LED on adapter board is highlight , then I can find the resource using VISA. If I stop the server, VISA can not find these resources.
There are several applications to operate the card which is delivered by vendor, I guess application get data from "Server" or "software module" using VISA, the manual told the application demand NI VISA runtime.
Under the application folder, I found some 16bit DOS software called "software module" , document told these DOS module manage the data flow between PC and instr.
I am not familiar with such a architecture but I need to program my own software to operate the instrument.
Attachment is the organization of the system provided by supplier's doc.
Maybe my knowledge is not enough to understand such a system,
Thanks for your sincerely reply.
Rexxar
*The best Chinese farmer*
(3,621 Views)
My description is not clear, not good to understand?
(3,596 Views)
En, What is your developing Language? C, VB, LabVIEW? I think in this instance, you can simply use VISA to communicate your instrument through RS232. Just like you use Serial (RS232)Device as long as the service is on and you can identify these instruments as if they are connected through Serial(RS232)
(3,583 Views)
