‎02-22-2006 06:08 PM
‎02-23-2006 01:46 AM
‎02-23-2006
08:02 AM
- last edited on
‎09-25-2026
11:33 AM
by
Content Cleaner
To add to the previous response, you can find a table of ASCII codes in the following Knowledge Base:
ASCII Table [link removed; article no longer available]
By looking at this table you can determine which backslash codes to use. You can use a hex code after the backslash, so using the example of commands you mentioned, and the table, we can see that:
ENQ = \05
STX = \02
CR = \0D or \r
You can find more information about the backslash codes by looking in the LabVIEW Help. Just switch to the index tab and search for "backslash"
Jason S.
Applications Engineer
‎02-23-2006 10:43 AM
Much thanks to you both! It is responding now 🙂
Adam
‎03-14-2013 05:47 AM
Hi Ibiaza,
I also have a peristaltic pump manufactured by MasterFlex. Somehow, it works with their program but when I try to send commands from Hyperterminal, it doesn't. Also there is no answer on my PC screen. I have a baud rate of 9600, 8 data bits, parity none, stop bits 1, and flow control none. Could you please help me out on this matter? I wonder if you would be so kind to send me some commands that work for you. My email address is raresstanciu@yahoo.com.
Thank you and best regards,
rares
