ViSA read buffer Search
Hi, using VISA read, I get my data from serial port and should wait until I get the  ! Sign (Hex Sting, 21).
All my tries to compare this with what I get from read buffer has bin failed.
I can simply find the  ! sign, but the result of  the comparison of this with constant Hex String is always false.(I use equation for comparison)
I also tried to convert the read buffer string first to byte U8 then get the number and check this with 33 bud didn't work as well.
I appreciate any help.
(3,551 Views)
What you probably need is the Search/Split String.  Can you supply some code so we can figure out what you are trying to do?
(3,545 Views)
Probably you also can look at this example....
https://decibel.ni.com/content/docs/DOC-14111
(3,507 Views)
