Reassemble bit with VISA Labview
I've problem with receiving data in Labview.
My receiver data is xbee and my transmitter data is xbee using arduino. I want to transmit analog read from arduino using xbee to another xbee (connect to labview). since, analog read from arduino is 10 bit and xbee only can send 8 bit, so I programmed my arduino to split the data into 8 bit and 2 bit in an array then xbee start to transmit the data.
The problem is i need to reassemble my data from 8 bit and 2 bit into 10 bit in Labview,
I'll attach my VI and arduino Code, thanks
(2,675 Views)
Just to confirm, in the end, you will use the 10 bit to convert them into a number right?
(2,629 Views)
Yes, right
(2,624 Views)
