Read Termination Character
Hi all,
I have a serial read problem.  I have 26 byte at buffer, but the read is only reading 25.  I saw that the last (25th) byte was 0A, which is a line feed, so it stopped reading when it read 0A.  However, I set ASRL End In to None before the read operation, so why is it still terminating a read operation at a line feed character?  I confirmed with NI spy that the read operation was terminated due to a termination character.
See BD for more information.
Yik
(3,476 Views)
Accepted by topic author jyang72211
Try setting TermChar En to false as well. I've always set them to either True/TermChar or False/None. Not sure what happens to True/None.
(3,473 Views)
That's exactly what I need.  Thanks!!!
Yik
(3,462 Views)
