Read Termination Character
Hi all,
I have a serial read problem.  I have 26 byte at buffer, but the read is only reading 25.  I saw that the last (25th) byte was 0A, which is a line feed, so it stopped reading when it read 0A.  However, I set ASRL End In to None before the read operation, so why is it still terminating a read operation at a line feed character?  I confirmed with NI spy that the read operation was terminated due to a termination character.
See BD for more information.
Yik
Kudos and Accepted as Solution are welcome!
(3,472 Views)
Accepted by jyang72211
Try setting TermChar En to false as well. I've always set them to either True/TermChar or False/None. Not sure what happens to True/None.
(3,469 Views)
That's exactly what I need.  Thanks!!!
Yik
(3,458 Views)
